No, the ear pads on the gaming headset are not replaceable.
- Is Wyze Wireless Gaming Headset compatible with hearing aids?
- Are the ear pads replaceable?
- What's the difference between Wyze Wireless Gaming Headset and Wyze Headphones?
- Is Wyze Wireless Gaming Headset compatible with Steam Deck or Stadia?
- Is the USB dongle pre-paired to the headset?
- Will the ear pads warp or damage over time from sweat?
- Can I use the gaming headset while charging?
- Can you customize the audio levels?
- How do I mute the gaming headset's microphone?
- Does the gaming headset support 3D audio?
- See more
