Charging with Wyze Solar Panel
Wyze Solar Panel lets you extend the length of time you can keep your Wyze Cam Outdoor or Wyze Battery Cam Pro (requires Wyze Solar Panel USB-C Adapter Cable) recording without having to bring it back inside to recharge. Wyze Solar Panel will not charge other devices, like your phone or other cameras.
To use Wyze Solar Panel:
  1. Insert the micro USB cable securely into the waterproof sleeve of the power adapter.
  2. Remove the silicone cover from the charging port of the camera, then insert the micro USB end of the power adapter firmly into the port.
    • For Wyze Cam Outdoor v1/v2: The silicone cover is located on the back of the camera.
    • For Wyze Battery Cam Pro: The silicone cover is located on the bottom of the camera.
    • Requires Wyze Solar Panel USB-C Adapter Cable.
  3. You're all set!
Additional Notes:
  • Wyze Solar Panel will stop charging the attached Wyze Cam Outdoor v1/v2 or Wyze Battery Cam Pro once the battery level reaches 100%. Once the battery level drops below 90%, the solar panel will resume charging the camera.
  • Wyze Solar Panel needs direct sunlight in order to charge. It will not charge during the night.
