How do I sign up for and purchase from TikTok Shop?
If you’re a content creator, you can sign up for and buy Wyze products from TikTok Shop using the steps below.
Required for TikTok Shop
In order to have TikTok Shop access, you’ll need to meet the following requirements:
  • Have over 5,000 followers
  • Be at least 18 years old
Apply for TikTok Shop
To apply for TikTok Shop access, you’ll want to follow the instructions below:
  1. Open your TikTok app and sign into your account.
  2. Tap Profile, and tap the Shop icon.
  3. Select Creator tools.
  4. Tap TikTok Shop for Creator, then Apply.
  5. Tap Inbox and tap on the message with the subject “Apply for TikTok Shop”.
  6. Once your application is approved by TikTok, you’re ready to shop!
Purchase from TikTok Shop
Here are some steps to help you get started with purchasing from Wyze on TikTok Shop:
  1. Search for Wyze and tap the Shop icon.
  2. Select which Wyze product you want to purchase and tap Buy sample.
    1. If you would like to make affiliate videos using Wyze products that you already have, you’ll want to tap Add.
