My Wyze Wi-Fi Chime won’t ring.
Problem
When I press the button on my paired Wyze doorbell, my Wyze Wi-Fi Chime doesn’t ring.
Troubleshooting
    3. Compare your app version to the latest app version listed on our Release Notes & Firmware page.
  2. If possible, check that both your Wyze doorbell and Wyze Wi-Fi Chime firmware are up to date.
    2. If there is an update available for the doorbell or chime, please move forward with updating it.
  3. Verify that Wyze Wi-Fi Chime is connected to your paired Wyze doorbell.
    1. In the Wyze app, navigate to Wyze Wi-Fi Chime’s settings > Automations.
    2. Ensure an automation is set up to trigger the chime to sound when your Wyze doorbell button is pressed.
  4. Increase the volume of the chime.
    1. In the Wyze app, select your Wyze Wi-Fi Chime.
    2. Under Volume, increase the slider bar.
  5. Restart the chime.
    1. Navigate to Wyze Wi-Fi Chime’s settings > Restart Chime > Restart.
  6. If possible, try moving the chime, doorbell, and router closer together.
