Cam Unlimited Pro Setup Guide
Get started with Cam Unlimited Pro by purchasing the subscription plan from Wyze Web Portal, then making sure you accept the terms during checkout or in the Wyze app. That's it!
To set up Cam Unlimited Pro:
  1. From your computer, log into your account at my.wyze.com.
    • Use the same email and password you use for the Wyze app.
    • You must subscribe at my.wyze.com, not the Wyze app.
  2. From the comparison chart, click Get Started on the Cam Unlimited Pro card.
  3. On the Start Subscription page, select Annual or Monthly to determine your plan type.
  4. Enter your payment details and click Save card.
  5. Click Subscribe to Unlimited Pro.
    1. You will be prompted to enable Descriptive Alert, one of the key features of Cam Unlimited Pro.
    2. You may be prompted to select or update the firmware your cameras.
    3. You may have to cancel any older security plans attached to your cameras.
  6. You're all set! Make sure you have the latest version of the Wyze app, then log in to check out Cam Unlimited Pro.
