Using Automations with Wyze Cam Outdoor
To learn all about Automations, Shortcuts, Schedules and Device & Service Triggers, start with the article: Using Automations with the Wyze app.
How do Automations work with Wyze Cam Outdoor?
Automations help control your Wyze Cam Outdoor, making it easier to turn it on/off with a single tap in the app, have it turn on/off at a scheduled time or when triggered by another device.
  • Shortcuts run actions with a tap in the Wyze app.
  • Schedules control devices based on the time of day.
  • Device & Service Triggers connect multiple Wyze devices so one can trigger another.
  • Location Triggers control devices based on your location.
An example Shortcut with Wyze Cam Outdoor
To create a shortcut to turn off notifications with a single tap from the Home screen.
  2. On the Add menu, tap Automation > Shortcut.
  3. Add a name for the shortcut in the text box under the star icon.
    • Try "Turn off notifications."
  4. Tap Add Action.
    1. Tap on your Wyze Cam Outdoor from the list.
    2. Tap Turn off notifications, then Save.
  5. When finished, tap Save.
Your shortcut will display at the top of the Automations tab. To add it to the Favorites tab, tap the star icon on the shortcut.
An example Schedule with Wyze Cam Outdoor
To create a schedule to turn on motion detection every day between 6:00 PM and 6:00 AM. This comes in handy when you want motion-triggered events outside when you're home.
  2. On the Add menu, tap AutomationSchedule.
  3. Tap Name (Optional).
    1. Enter a name for the schedule. Try "Turn on motion detection."
    2. Tap Save.
  4. Tap Add Action, then the Wyze Cam Outdoor you want to create a schedule for.
  5. Select Turn on motion detection, then Save.
  6. Tap Start Time.
    • Select 6:00 PM, then Save.
  7. Tap End Time (Optional).
    • Select 6:00 AM, then Save.
  8. Tap Save.
Pro Tip: You can also temporarily disable your notifications using our Snooze Notifications feature.
An example Device Trigger with Wyze Cam Outdoor
To create a device trigger that uploads a video to the cloud from your Wyze Cam when the sensor opens.
  2. On the Add menu, tap Automation > Device & Service Trigger.
    1. Enter a name for the schedule. Try "Upload a video when door opens"
    2. Tap Save.
  4. Tap Device & Service Trigger.
    1. Select your Wyze Entry Sensor.
    2. Tap Opens, then Save.
  5. Tap Add Action.
    1. Select your Wyze Cam Outdoor.
    2. Tap Upload a short video to the cloud, then Save.
  6. When done, tap Save.
An example Location Trigger with Wyze Battery Cam Pro
To create a location trigger to turn off notifications on Wyze Cam Outdoor when you arrive home.
  2. On the Add menu, tap Automation > Location Trigger.
    1. Enter a name for the trigger. Try "Turn off notifications when I arrive"
    2. Tap Save.
  4. Tap I arrive.
  5. Confirm the location displayed in the list.
  6. Tap Add Action.
  7. Optionally, tap to add a Time that this trigger is active.
  8. When done, tap Save.
