Snooze Notifications
Quickly turn off notifications for as long as you need to with the snooze notification feature!
To snooze notifications, open your Wyze app and tap the bell icon in the upper right-hand corner. You can snooze notifications for 30 minutes, for 1 hour, until tomorrow, or a custom time frame.
To turn notifications back on, simply tap the bell icon again. You should get a Push notifications turned ON pop-up message to confirm the change.
Notes:
  • These options are only available for Wyze app 2.43 and above. Not sure what app version you’re on? You can find this in your Wyze app by going to the Account tab > About. You can compare your app version to the latest app version listed on our Release Notes & Firmware page.
  • Shared users can independently manage their notification settings and use the Snooze button.
    • Note: This is available on Wyze Cam v3, Wyze Cam v3 Pro, Wyze Cam v4, Wyze Cam Pan v3, Wyze Video Doorbell v2, Wyze Battery Video Doorbell, Wyze Solar Cam Pan, Wyze Bulb Cam, and Wyze Cam Floodlight v2.
