How do I opt-in to Two-Factor Authentication?
New Wyze accounts now have Two-Factor Authentication (2FA) enabled by default, for better security and to help provide you with more control over who can access your account. But if you're already a Wyze user, you can opt-in to 2FA with just a few taps.
There are three methods available for Two-Factor Authentication:
  • Text message (SMS): Sends you a text containing the associated key or code.
  • Authenticator app: Pairs to your account, then continually generates codes on a short timer which act as the needed key.
  • Email: Sends you an email with a code to enter into the Wyze app.
To opt-in to Two-Factor Authentication:
  1. In the Wyze app, tap Account.
  2. Tap Account > Two-Factor Authentication.
  3. On the next screen, choose Verification by SMS or Verification by Authenticator App.
    • Verification by SMS
      1. Enter the phone number that you'd like to receive your verification codes.
      2. Tap Verify Phone Number.
        • You'll receive a text message with your verification code. Copy this code.
      3. Paste the code on the Enter Code screen, then tap Next.
      4. Optional step: Add a Backup Number. To skip, tap Skip for Now.
        • This number will only be used if your primary number is unusable.
        • A text will not be sent to the backup phone unless you tap Use Backup when logging in.
    • Verification by Authenticator App
      1. Open your authenticator app, and select the option to Add Account.
      2. Copy the code provided by the Wyze app to the Authenticator app.
        • If your preferred Authenticator app directs to QR entry, look for an option that lets you enter the code manually. The Wyze app will not provide you with a QR code.
      3. Once Wyze has been added to the authenticator app, copy the provided code from the Authenticator app to the Wyze app.
  4. You're all set!
Additional Notes:
  • Learn more about 2FA at Wyze in our articles Two-Factor Authentication and 2FA Updates and FAQs.
  • To opt-out of 2FA (text message or authenticator app), don't set it up in the app if you haven't already. If you already have it set up, go to Account > Account > Two-Factor Authentication and tap Disable 2FA (Not Recommended), then Yes, Disable to confirm.
