Every smart product from Wyze has a home in the Wyze app. From Wyze Cam to Wyze Thermostat, if it's connected, you can manage it in the Wyze app.
To get started with the Wyze app:
- Download the Wyze app from the Apple App Store or the Google Play Store.
- Once downloaded, tap the Wyze icon to open the app.
- Create a Wyze account, and/or sign in to your Wyze account.
- To create a Wyze account:
- Tap Sign up on the app screen.
- Enter your email address, then set a password for your account.
- Tap Continue.
- Follow the on-screen instructions to finish setting up your account.
- Connect your phone / tablet to your 2.4GHz WiFi network.
- Note: You must be connected to a 2.4GHz WiFi network to set up a Wyze device.
- All set? Tap on the + plus sign, then Add Device to set up your very first Wyze device!
Additional Notes
- The Wyze app is compatible with Android (7.0+) and iOS (14.0+) devices only.
- Using the Wyze app on an older device that doesn’t meet the requirements may cause compatibility issues.
- The Wyze app is not compatible with Windows phones/tablets or Kindle Fire tablets.
- The Wyze app does not work with Wyze Surge Protector or Wyze Handheld Vacuum, which are not connected / smart devices.
- If you have any problems downloading and using the Wyze app, make sure your device software is up to date.
