You can find actions like Take Photo, Siren, Turn Off, and Reorder on the menu bar under your Wyze Cam's livestream.
To reorder the actions on the menu bar:
- Swipe left on your Wyze Cam's menu bar, to the Reorder icon.
- In the pop-up, hold and drag the icons to your preferred order.
- Top left is the first action, bottom right is the last action.
- Tap Reset to Defaults to return to the default order.
- Tap Done.
