What's on the Wyze Cam menu bar?
The menu bar is the handy set of actions (options) below your Wyze Cam's Live stream, after you tap on it from the Home screen. It has actions like SD Card, Timelapse, Album, and Reorder.
Menu Bar Overview: Your actions may vary
The menu bar options change depending on which device you have, and if you've tapped one of the actions.
Menu bar for most fixed Wyze Cams:
Fixed Wyze Cams have the following options:
SD Card, Take Photo, Record, Siren, Smart Focus, Timelapse, Album, Turn Off, and Reorder.
Menu bar for pan-and-tilt Wyze Cams:
Pan-and-tilt Wyze Cams have the following options:
SD Card, Events, Waypoints, Take Photo, Record, Siren, Track Motion, Pan Scan, 360 Scan, Timelapse, Album, Privacy Mode*, and Reorder.
Note: *Wyze Cam Pan devices cannot be turned off, but use Privacy Mode instead.
Menu bar for Wyze doorbell devices:
Wyze Video Doorbells have the following options:
SD Card, Take Photo, Record, Siren, Responses, Album, and Reorder.
Note: Wyze Video Doorbell devices cannot be turned off.
Menu bar for Wyze Cam Floodlight devices:
Wyze Cam Floodlights have the following options:
SD Card, Floodlight, Take Photo, Record, Siren, Smart Focus, Timelapse, Album, Turn Off, and Reorder.
Menu bar for Wyze Bulb Cam:
Wyze Bulb Cams have the following options:
SD Card, Bulb, Take Photo, Record, Siren, Smart Focus, Timelapse, Album, Turn Off, and Reorder.
Menu bar for fixed Wyze Cams with an integrated spotlight:
Fixed Wyze Cams with an integrated spotlight* have the following options:
SD Card, Spotlight, Take Photo, Record, Siren, Smart Focus, Timelapse, Album, Turn Off, and Reorder.
*These cams include Wyze Cam v4, Wyze Cam v3 Pro, and Wyze Cam OG.
Menu bar for fixed Wyze Cams with a spotlight accessory:
Fixed Wyze Cams with a spotlight accessory* have the following options:
*This is includes Wyze Cam v3 with a paired Wyze Cam v3 Spotlight Accessory.
Menu bar for fixed Wyze Cams with a lamp socket accessory:
Fixed Wyze Cams with a lamp socket accessory* have the following options:
SD Card, Lamp Socket, Take Photo, Record, Siren, Smart Focus, Timelapse, Album, Turn Off, and Reorder.
*This includes Wyze Cam v3 and v4 with Wyze Lamp Socket v1, or Wyze Cam v3, v4 v3 Pro, v4, and OG with Wyze Lamp Socket v2.
