What's the effective range from Bridge to sensor?
There are a number of factors to take into consideration, like the floor plan and environmental factors which can interfere with signal strength. Because of these factors, there is no set distance, but we have seen that most homes should only require 1 Bridge.
If you do have connectivity issues, especially in a basement or far distances, consider moving the distance from the bridge to see if it creates a stronger connection.
