No, the vacuum should only be used on dry surfaces.
Wyze Robot Vacuum should only be used on dry flooring. It is not a wet/dry vacuum, and is not meant to be used on wet surfaces. Using the Wyze Robot Vacuum on wet surfaces could damage the device.
