Can Wyze Robot Vacuum work on multiple floors?
Yes, with multi-floor mapping!
Wyze Robot Vacuum can work on multiple floors with multi-floor mapping. Simply move your charging station and vacuum to the new floor, and add a floor in the Wyze app. You can add up to 5 floors.
To use multi-floor mapping:
  1. Move the charging station and the vacuum to the new floor, plugged into power.
  2. In the Wyze app, tap on your Wyze Robot Vacuum. Make sure you have the multi-floor option. If not, check your app for updates.
  3. Tap the multi-floor icon, then Add a floor.
  4. Tap Start quick mapping.
💡 Tip: Make sure the new floor is clear of anything you do not want vacuumed up, or that doors are closed to areas you do not want mapped.
