How do I clean my vacuum's Main Brush?
Use the cleaning tool or scissors to cut through debris.
To clean the Main Brush:
  1. Remove Wyze Robot Vacuum from the charging station.
  2. Lift the vacuum's top cover, and locate the cleaning tool near the dustbin.
    • Close the top cover.
  3. Turn the vacuum upside down.
  4. Remove the Main Brush from the vacuum.
  5. Use the cleaning tool to clean the brush.
    • The tool has one end with a hook and metal edge for cutting hair and particles tangled in the Main Brush.
  6. When clean, replace the Main Brush and cleaning tool, and put the vacuum right-side up.
  7. Reconnect the vacuum to the charging station.
