How far can I put Wyze Plug Outdoor from my house?
Up to 300 feet (but it depends).
Wyze Plug Outdoor has long-range WiFi to ensure it can be used in many locations. It can reach up to 300 feet in an open environment but the exact distance will depend on the location (how many walls between the hardware, the building materials, etc.).
Important: Wyze Plug Outdoor should be plugged directly into your power outlet. We do not recommend connecting the outdoor plug to an extension cord as this could result in damage to your Wyze device and void your device's warranty.
