The monitoring resolution for Wyze Plug Outdoor is accurate to 0.1 KWH.
- Can I use Wyze Plug Outdoor with an extension cord?
- How do I turn on automatic updates for my outdoor plug?
- What is the energy monitoring resolution and accuracy?
- Is monitoring done on each socket independently or combined?
- Is my energy usage stored indefinitely or is it limited?
- Does Wyze Plug Outdoor work with 220V?
- Does Wyze Plug Outdoor need to be specially mounted?
- Can I manually turn Wyze Plug Outdoor on and off?
- Do I need Wi-Fi to use the outdoor plug?
- How does the light sensor feature work?
- See more
