How do I clean the HEPA filter?
Remove it from the vacuum, and rinse with water.
  1. Rotate and remove the dust cup, then rotate and remove the prefilter gauze.
  2. Pull the HEPA filter out of the prefilter gauze and rinse it with tap water.
  3. Once dry, reassemble the handheld vacuum.
