How do I create a virtual wall?
To create a virtual wall:
  1. In the Wyze app, tap on your Wyze Robot Vacuum.
  2. On the bottom right of your map, tap the square edit icon  WRV_Virtual_walls.png.
  3. Tap + Add a virtual wall.
  4. Tap and drag the red square to move it, and pinch to resize it.
  5. Tap OK to save your virtual wall.
