How do I create a room?
If you want to separate your map into rooms or different areas, edit the map in your Settings.
To create a room:
  1. In the Wyze app, tap on your Wyze Robot Vacuum.
  2. Tap on the Settings gear on the top right.
  3. Tap the pencil icon.
  4. Tap on your map to open an area and edit it.
  5. Tap Split to separate an area into to 2 spaces.
    • Tap and drag the line to edit the size and placement of the room.
  6. Tap OK to confirm your changes.
    • Tap Back to cancel your changes.
  7. Continue to tap and split to create more rooms.
Want to name your rooms?
  1. Tap on the room or area.
  2. Tap Rename.
  3. Enter a new name, then tap OK.
Want to merge your rooms?
  1. Tap the rooms you want to merge.
  2. Tap Merge.
