Does Wyze Floor Lamp’s bulb change colors?
No, Wyze PARB Bulb does not change colors.
Wyze Floor Lamp’s bulb does not change colors or color temperature. The color temperature is 4000K, or Cool White.
You can adjust the brightness, however, using the included remote button or the Wyze app.
