How far away can the remote be from Wyze Floor Lamp?
The remote can be up to 50 feet away from Wyze Floor Lamp.
You can use the remote up to 50 feet away from the lamp, connected via BluetoothⓇ. This may vary depending on if there are any obstacles in the way, like walls, doors, and furniture.
