Can I use other bulbs in Wyze Floor Lamp?
No, only use the included PARB Bulb in Wyze Floor Lamp.
Wyze Floor Lamp is a smart lamp that is embedded with special technology so that the bulb and remote work together with the Wyze app. Other E26 base bulbs, even other Wyze smart bulbs, cannot connect with the remote or Wyze Floor Lamp in the Wyze app. You won’t be able to turn off the light with the cord switch or control it with the remote button.
Lastly, the included Wyze PARB Bulb has a minimalist aesthetic design that fits perfectly in the lamp assembly. Other bulbs just can’t compare!
Still need help?
