No, Wyze Buds Pro uses Adaptive EQ to automatically adjust the sound.
- Do Wyze Buds Pro have extra silicone tips?
- Does Wyze Buds Pro work without the Wyze app?
- Will there be a budget version of Wyze Buds Pro?
- Do Wyze Buds Pro come with a wireless charger?
- Are they compatible with gaming consoles and computers?
- Do they produce mono, stereo, or surround sound?
- Can you adjust the noise cancelling levels?
- What kind of noise cancelling do they use?
- Can you customize the EQ of Wyze Buds Pro?
- Can I connect Wyze Buds Pro to two devices at the same time?
- See more
