About Wyze Night Light
Illuminate the night with soft, motion-activated light.
Features that help Wyze Night Light lead the way:
  • Linkability: Link up to 10 Wyze Night Lights with the flip of a switch. When one night light turns on, all others will, too.
  • Dusk to Dawn + Motion Sensors: Built-in light sensor lets the night light only turn on when you need it most. The PIR motion sensor also means the light will only turn on when motion is detected.
  • Rechargeable Lithium Battery: Save your batteries! Wyze Night Light has an internal lithium battery that can be easily recharged with a USB-C cable.
  • Easy on the eyes: A 2500K warm, soft white color temperature means more comfortable light for the night.
  • Effortless Installation: Included easy-pull tape and metal plate means mounting the night light is easy. No app setup required.
