Before you begin setup:
- Download the Wyze app on your smartphone or tablet.
- Connect your device to a 2.4 GHz Wi-Fi network, and enable BluetoothⓇ.
- Unpack your Wyze Solar Cam Pan box, removing all plastic and packing materials.
- Be sure to remove the plastic film from the lens.
- Plug the camera into power using the provided Type-C cable, and a 5V/2A adapter (not included).
- You must fully charge Wyze Solar Cam Pan before setup and installation.
- The camera’s status light will turn solid red while charging, and solid blue when charging is complete.
To set up your Wyze Solar Cam Pan:
- In the Wyze app, tap Home, then tap + plus sign on the top right.
- On the Add menu, tap Device.
- Tap Cameras > Pan and Tilt Camera > Wyze Solar Cam Pan.
- Ensure that your camera is fully charged. Tap Begin Setup.
- The camera's status light will be solid red when charging, and solid blue when fully charged.
- Single-press SETUP on top of the camera. The camera will say "ready to connect." In the app, check the box next to It said, Ready to connect".
- Tap Next.
- If BluetoothⓇ hasn't been enabled, you will be prompted to allow BluetoothⓇ and location access. Tap Next.
- If BluetoothⓇ and location access has already been enabled, it will skip to the next step.
- The app will automatically begin searching for and pairing with your Wyze Solar Cam Pan.
- If you have multiple Wyze Solar Cam Pans, select the correct camera by tapping the MAC address that matches the address on the top of the camera.
- Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Next.
- Tap the icon in the password field to display the password to ensure it was entered correctly.
- Your device will continue pairing. Once paired, tap Next.
- Once connected, the app will show an installation guide with placement tips.
Check out: Wyze Solar Cam Pan Installation Guide- If you want to use the installation guide now, tap Next.
- If not, tap Skip.
- Now it's time to set up your Home Waypoint, your cam's default view. Tap Continue.
- The Home Waypoint is required for this initial setup.
- Once your camera connects to the live stream, the camera will automatically calibrate for accurate positioning.
- Use the arrows in the app to pan/tilt your camera until you reach your desired Home position. Tap Set and then tap Next.
- Camera mounted upside down? Tap Rotate 180° to flip the live stream.
- Name your camera using the text field, or by choosing a suggestion. Tap Next.
- You may be prompted to try a Wyze security plan, if you're not already a subscriber. Tap Continue.
- Set up some automations on the Things to Try page, or tap Skip then Done.
- Enjoy your new Wyze device!
