Wyze Scale Ultra BodyScan Setup Guide
To set up your Wyze Scale Ultra BodyScan:
Before starting, insert the batteries into your Wyze Scale Ultra BodyScan. Then place it on a hard, flat surface and enable Bluetooth on your phone.
  2. On the Add menu, tap Device.
    • Step on the scale to activate it. Make sure your device's BluetoothⓇ is enabled.
    • Your weight will display on your device and Wyze Scale Ultra BodyScan.
  3. Tap Lifestyle > Wyze Scale Ultra BodyScan.
    • Your phone will search for your scale, pair with it, and connect to it.
  4. Name your device or choose a pre-selected name, then tap Save.
    • You can add this device to your Favorites by leaving the box checked.
  5. Add your details (Year of Birth, Height, etc.).
    • You must be between 10 and 100 years old to get Body Composition data.
  6. Tap Next. Your phone or tablet will pair with your scale again.
  7. A Setup Wi-Fi popup will appear. Tap Yes.
    • Or tap No to skip. You can set this up later in your scale’s settings.
  8. Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Next.
    • Tap the icon in the password field to display the password to ensure it was entered correctly.
  9. Once Wi-Fi has successfully connected tap Ok and you’re all set!
New to Wyze? Before starting, download the Wyze app and enable Bluetooth.
