Will the climate sensor work beyond the listed operating temperature?
Yes, but the accuracy may be off.
If you're using your climate sensor in really cold or really warm weather, the climate sensor's accuracy will be decreased. We do not recommend using the climate or leak sensors beyond the specified operating temperature: 32ºF-104ºF (0ºC-40ºC).
