Dusk-to-Dawn is not Working.
Problem:
The night light does not come ON at dusk or turn OFF at dawn.
Troubleshooting Tips:
  • Make sure the night light power switch is set to either ON or AUTO.
    • If the power switch is set to ON, try charging the night light for about 2 hours to see if that alleviates the issue.
  • If the power switch is set to auto, try power cycling your Night Light.
    • To power cycle, your Wyze Night Light, simply turn the power switch to OFF and then turn it back ON.
