Wyze Sense Climate Sensor Setup Guide
To set up Wyze Sense Climate Sensor:
  2. On the Add menu, tap Device.
  3. Tap Sensors > Wyze Climate Sensor.
  4. On the next screen, select the hub you want to connect your sensor to.
  5. Remove the plastic battery tab that is located on the back of the sensor.
  6. Press and hold the reset button on the side of the sensor until the light flashes.
  7. The setup will complete automatically.
  8. Name the sensor once the setup finishes.
  9. Set up some automations on the Things to Try* page, or tap Skip.
  10. You’re all set. Enjoy your new Wyze device!
Where to place Wyze Climate Sensor
Now that you have added the sensor to the Wyze app, the sensors can be mounted using the included adhesive on the back of the sensor.
Note: Before sticking your sensor to a surface, move it to the area you plan to mount it and test it to make sure it works at this distance from your Wyze Sense Hub.
Mount by cleaning the surface and removing the paper from the adhesive backing before placing it. Keep in mind that the adhesive should be considered permanent, so make sure it’s where you want the sensor prior to mounting!
