Wyze Sense Leak Sensor & Leak Sensor Probe Setup Guide
To set up Wyze Sense Leak Sensor:
  2. On the Add menu, tap Device.
  3. Tap Sensors > Wyze Leak Sensor.
  4. On the next screen, select the hub you want to connect your sensor to.
  5. Using a screwdriver, unscrew the back cover of the sensor and remove the cover. Remove the plastic tab from the sensor’s battery compartment by pulling the plastic tab.
  6. Press and hold the reset button on the side of the sensor until the light flashes.
  7. The setup will complete automatically.
  8. Name the sensor once the setup finishes.
  9. Set up some automations on the Things to Try* page, or tap Skip.
  10. You’re all set. Enjoy your new Wyze device!
To set up Wyze Leak Sensor Probe:
  • To set up your Wyze Leak Sensor Probe, simply plug it into your Wyze Sense Leak Sensor.
  • Once it is successfully paired, you’ll see a plus symbol in the top right corner of the Wyze Sense Leak Sensor page.
