What is Wyze Web View?
Wyze Web View is a convenient way to access your Wyze Cam's live stream and Event playback from a web browser on PC, Mac, smart TV, or tablet.
To use Wyze Web View:
  1. From a supported browser, go to https://my.wyze.com/live.
    • Recommended browser: Google Chrome*
  2. Hover and click the play button on any video feed that's available.
We highly recommend using Wyze Web View on the latest version of Chrome. Download Chrome
If any of your devices do not support Wyze Web View, there'll be an alert (!) message letting you know.
Shared Users and Wyze Web View
You must have a subscription to Cam Plus, Cam Unlimited, or Cam Unlimited Pro assigned to your Wyze Cam to stream all of your cameras on Wyze Web View.
  • If you're a shared user with your own security plan, you can use Wyze Web View to stream all of your own compatible cameras. You cannot stream any shared cameras.
  • If you're a shared user without your own security plan, you can stream 1 shared compatible camera with Wyze Web View, as long as it has a security plan attached.
  • If you're a shared user without your own security plan, you can view shared cameras from the Monitoring tab using the Multi-Cam timeline feature in the Wyze app.
  • In Wyze Web View, a lock icon will display on any camera without a security plan attached.
What browsers are recommended for Wyze Web View?
Wyze Web View works best on Google Chrome.
Wyze Web View is not supported on Firefox browsers.
Which Wyze Cams are compatible with Wyze Web View?
Currently, Wyze Web View allows you to view the Live stream and Event videos on the following devices:
  • Wyze Indoor Cam Pan
  • Wyze Bulb Cam
  • Wyze Window Cam
  • Wyze Cam Floodlight Pro
  • Wyze Cam Floodlight v1
  • Wyze Cam Floodlight v2
  • Wyze Cam OG
  • Wyze Cam OG Telephoto 3x
  • Wyze Cam Pan v1
  • Wyze Cam Pan v2
  • Wyze Cam Pan v3
  • Wyze Cam Pan v4
  • Wyze Duo Cam Pan
  • Wyze Solar Cam Pan/2K
  • Wyze Cam v2
  • Wyze Cam v3
  • Wyze Cam v3 Pro
  • Wyze Cam v4
  • Wyze Duo Cam Doorbell
  • Wyze Video Doorbell v1
  • Wyze Video Doorbell v2
  • Wyze Battery Cam Pro
Wyze Web View also allows you to view the Events only on the following devices:
  • Wyze Cam Outdoor v1
  • Wyze Cam Outdoor v2
  • Wyze Video Doorbell Pro
Wyze Web View is not available on Wyze Cam v1.
Additional Notes:
  • Free users without a subscription can select one camera to livestream on Wyze Web View per month.
  • Wyze Web View is not available in the Wyze app.
