How do I clean the floodlight before applying the filters?
Two small cleaning wipes are included in the package, but you can also use similar electronics cleansing wipes or a soft microfiber towel. No need for soapy water! Do not use abrasive materials, sharp objects, harsh chemicals, or rough cloths, as these may damage the lamp head surface.
