How do I maintain my Wyze Scale device?
Wyze Scale device maintenance tips:
  • Keep your scale clean.
    • As needed, wipe the scale surface with a cloth dampened with water.
    • Do not use bleach, organic solvents, or other chemicals on the scale.
  • Remove the battery if you won't use your scale for over a month.
  • Avoid shocks. Don't jump on it.
  • Do not disassemble your scale.
Note: This applies to the original Wyze Scale, Wyze Scale S, Wyze Scale X, Wyze Scale Ultra, Wyze Scale Ultra BodyScan, and Wyze Scale Ultra BodyScan Plus.
