Wyze Scale BodyScan Setup Guide
To set up your Wyze Scale BodyScan
Before starting, insert the batteries into your Wyze Scale BodyScan. Then place it on a hard, flat surface and enable Bluetooth on your phone.
  2. On the Add menu, tap Device.
  3. Tap Lifestyle > Wyze Scale BodyScan.
    • The app will search and pair with your Wyze Scale BodyScan.
  4. Step on the scale to activate it quickly, so it can connect with your Wyze app.
  5. Name your device or choose a pre-selected name, then tap Save.
  6. Add your details (Year of Birth, Height, etc.), tap Next.
    • You must be between 10 and 100 years old to get Body Composition data.
  7.  You're all set! Enjoy your new scale.
New to Wyze? Before starting, download the Wyze app and enable Bluetooth.
