Yes, you can mount Wyze Window Cam Wedge Mount upside down to tilt the camera's view upward.
- Wyze Window Cam Wedge Mount Installation Guide
- Wyze Window Cam Wedge Mount Tech Specs
- Can I use Wyze Window Cam Wedge Mount outdoors or in damp locations?
- Can I mount the wedge upside down to angle the camera upward?
- Can I mount the sticker vertically to angle the camera left or right?
- Why is the mounting sticker bigger than the camera?
- Can I mount Wyze Window Cam Wedge Mount on a window with a screen?
