To turn on Smart Track on Wyze Cam Pan v4:
In the Wyze app, tap on your Wyze Cam Pan v4.
Under the live stream, swipe left/right on the toolbar to find Smart Track.
Tap the icon to turn it on or off.
When green, Smart Track is On.
When grey, Smart Track is Off.
Using the pan and tilt features, whenever motion is detected, Wyze Cam Pan v4 can move to track the motion until it stops.
This feature is only available on Wyze Cam Pan devices.
Choosing what Smart Track follows
Wyze Cam Pan v4 uses AI-powered object tracking, so you can choose whether the camera follows all motion or prioritizes specific subjects.
In the camera's settings, tap Pan Cam Controls.
Under Smart Tracking, choose All Motion or Smart Tracking.
All Motion: The camera will follow all motion detected.
Smart Tracking: Choose from AI options (Person, Vehicle, Pet).
Use the Reorder button to arrange them, placing the object you want prioritized at the top of the list.
Additional Notes:
When the camera detects motion, it will move to follow the object to keep it within the camera's field of view.
Once out of view, the camera will return to its Home Waypoint.
If Smart Track is set to All Motion and multiple objects are moving at the same time, Wyze Cam Pan v4 will follow the largest moving object in view.
If Smart Track is set to an AI option, the camera will prioritize the subject type highest on your Reorder list (for example, Person over Pet or Vehicle) when more than one is detected.
After a period of inactivity (no motion detected), Wyze Cam Pan v4 will return to its Home Waypoint OR continue its Pan Scan if one was in progress.
Smart Track can be turned on and off independently of Motion Detection and Motion Tagging.
