Will I get a notification if my garage door opens or closes?
Yes, via the Wyze app.
With notifications turned on in the Wyze app, you will receive a notification whenever your garage door opens or closes. You can also receive a notification if the garage door has been left open.
You can change these settings, or disable notifications, in the Wyze app.
