How do I adjust my Wyze Garage Door Controller’s trigger duration?
You can do this in the Wyze app!
Some garage openers use a non-standard trigger duration, or the time between when the garage wall button is pressed and when the garage opens.
You can change this through the Wyze app if you find that your Wyze app isn’t fully opening or closing your garage door, is automatically opening after each close or vice versa, or you just want a change when opening your garage.
To adjust the Trigger Duration for your Wyze Garage Door Controller:
  1. Navigate to your Wyze Cam v3 connected to your Wyze Garage Door Controller in the Wyze app.
  2. Tap Settings. > Accessories > Garage Door Controller.
  3. Tap Trigger Duration.
