Wyze Scale BodyScan Plus has all the features of Wyze Scale Ultra BodyScan, but adds a vibrant, customizable 4.3-inch full-color TFT handle display.
Wyze Scale X |
Wyze Scale Ultra |
Wyze Scale Ultra BodyScan |
Wyze Scale Ultra BodyScan Plus |
| # of Electrodes | 4 | 4 | 8 | 8 |
| TFT Screen | No |
Yes |
Yes |
Yes, in-handle |
| Colors | Black, White | Black, White | Black, White | Black, White |
| Weight | 3.96 lbs (1.80 kg) | 3.96 lbs (1.80 kg) | 5.95 lbs (2.7 kg) | 5.95 lb (2.7 kg) |
| Size | 11.8 in x 11.8 in x 1.18 in | 11.8 in x 11.8 in x 1.1 in | 11.81 in x 11.81 in x 1.50 in | 11.81 in x 11.81 in x 2.01 in |
| Power | 4x AAA batteries | 4x AAA batteries | 4x AAA batteries | 4x AAA batteries |
| Surface | ITO coated glass | ITO coated glass | ITO coated glass | ITO coated glass |
| Battery Life | Up to 22 months with Power Saver Mode | Up to 9 months with Power Saver Mode | Up to 8 months with Power Saver Mode | Up to 9 months with Power Saver Mode |
| Baby/Pet/Luggage Mode | Yes | Yes | Yes | Yes |
| BodyScan Handle | No | No | Yes | Yes, w/ screen |
| Age Range | 10-100 years old | 10-100 years old | 10-100 years old | 10-100 years old |
| Weight Range | 11-400 lbs | 11-400 lbs | 11-400 lbs | 11-400 lbs |
| Factory Reset Support | Yes | Yes | Yes | Yes |
| Heart Rate | Measured by covering your mobile device’s camera with your finger | Measured by covering your mobile device's camera with your finger | Measured by covering your mobile device's camera with your finger | Measured by covering your mobile device's camera with your finger |
