Wyze Solar Cam Tech Specs
Wyze Solar Cam Device Details
Color: White
Finish: Textured Matte
Materials: Body: Polycarbonate; Lens: Glass + Plastic
Camera Dimensions: 96 mm (H) x 51 mm (W) x 60 mm (D)
Solar Panel Dimensions: 103 mm x 103 mm x 18.6 mm
Camera Weight: 8.04 oz (228 g)
Camera + Solar Panel Weight: 18.94 oz (537 g)
Powering Methods
Power Cable: Tupe-C to USB-A
Cable Length: 2 feet (0.6 m)
Power Adapter Output: 5V/2A (not included)
Power Input: 5200mAH battery, 3.6V
Power Output: 5V/2A
Battery: 5200 mAh, non-removable Lithium-ion battery
Charging time: 0-100% in 4-6 hours using the provided cable/adapter
Solar Power: Adjustable and Detachable 1.8 W Solar Panel With solar panel, forever=
Mounting Features
Included Ceiling and Wall Mount, Tabletop
Audio & Video
Resolution: 2K, 2304 x 1296 (3MP)
Camera
Image Sensor: 1/2.7'' CMOS
Digital zoom: 8x
Field of View: 130°
Night Vision
2 IR LEDs (850 nm) Color Night Vision
Spotlight: Built-in 100lm motion-activated spotlight
Video
Video encoding: H.264
Frame rate:
- Day time video: 20 FPS
- Night vision: 15 FPS
Audio
Siren: 107 db
Built-in microphone, digital
2-Way Audio
Alerts
Push notifications
Storage
Cloud Storage
Stored in the AWS Cloud*
  • Wyze Services subscription required
Local Storage (microSD card required):
  • Supports 8-32 GB microSD cards in FAT32 format
  • Supports up to 256 GB microSD cards in exFAT format
Local Storage
Connectivity
802.11 b/g/n, 2.4GHz Wi-Fi, Wi-Fi 6
BLE 5.3 setup, Wi-Fi 6, 2.4GHz
Supports WPA and WPA2 protocols
Integrations
Alexa, Google Assistant, IFTTT
Phone Compatibility
Supports Android 10.0+ and iOS 16.0+ or later
Operating Temperature
-4°F - 122°F / -20°C - 50°C
Weather Resistance
Indoor and outdoor (IP65)
Language
English
Warranty
1-Year
