Yes, Wyze Battery Cam supports Bluetooth setup for fast and seamless pairing with the Wyze app.
- Can I power cycle Wyze Battery Cam?
- Is Wyze Battery Cam weatherproof?
- Can I record continuously to a microSD card on Wyze Battery Cam?
- Do I need a base station for Wyze Battery Cam?
- Does Wyze Battery Cam support Bluetooth setup?
- Does Wyze Battery Cam include deterrent features?
- Is Wyze Battery Cam complicated to install?
- Is Wyze Battery Cam compatible with Wyze Web View?
- What’s new with Wyze Battery Cam and Wyze Solar Cam?
