Can I use Wyze Scale X with my shoes on?
Yes, but it will only measure your weight.
Yes, but if you step on the scale with socks and/or shoes on, Wyze Scale X will only be able to measure your weight. To take your other body composition measurements (ex. Body Fat %, Water %) you will need to step on the scale with both feet while barefoot.
