How do I leave the beta app?
You can find instructions on leaving beta below.
For Android users:
  1. Log into your Wyze app.
  2. Tap Account > About > Beta Program.
  3. At the bottom of the screen, tap Leave.
  4. To completely opt out of testing:
    1. Navigate to your Google Play Store and search for the Wyze app.
    2. Scroll down to App support and tap Leave.
    3. Tap Leave again in the pop-up.
  5. Delete the beta app and install the public version of the Wyze app from the Google Play Store.
    • Note: It may take up to 24 hours to see the public version of the Wyze app.
For iOS users:
    1. Open the TestFlight app and find Wyze.
    2. Scroll down and tap Stop Testing.
  5. Delete the beta app and install the public version of the Wyze app from the Apple App Store.
You're always welcome to rejoin the program again in the future if you change your mind! Please note that iOS has a limit for the total number of users that can utilize the beta version of the app. If you're unable to join the beta app right now, please try again in the future!
