No, the color temperature cannot be changed on Wyze Cam Floodlight v2. The floodlight panels color temperature is 5000K.
- How to use Motion Warning on your Wyze Cam
- Is Wyze Cam Floodlight v2 weatherproof?
- What is the Access Point feature?
- Can I change the color temperature of Wyze Cam Floodlight v2?
- Does Wyze Cam Floodlight v2 have local storage?
- Does Wyze Cam Floodlight v2 come in other colors?
- Can I change the brightness of the floodlights?
- What is the Motion Detection range for Wyze Cam Floodlight v2?
- What is the Motion Warning feature on Wyze Cam Floodlight v2?
- Does Wyze Cam Floodlight v2 support 5 GHz Wi-Fi?
