How to use Motion Warning on your Wyze Cam
Turn on the Motion Warning feature so that a voice alert plays and lets visitors know your home is protected by Wyze.
When enabled, your Wyze Cam or doorbell will either play a Wyze Tone, or:
"Hi, you are currently being recorded."
Motion Warning is available on these Wyze Cams and doorbells:
  • Wyze Cam Floodlight v2
  • Wyze Cam Floodlight Pro
  • Wyze Cam OG and Telephoto 3x
  • Wyze Cam v4
  • Wyze Video Doorbell v2
  • Wyze Duo Cam Doorbell
To turn Motion Warning on and off:
  1. In the Wyze app, tap on your Wyze Cam or video doorbell.
  2. Tap on the Settings gear.
  3. Tap Detection Settings > Motion Warning.
  4. To turn on Motion Warning, tap Wyze Tone or You are being recorded.
  5. To turn off Motion Warning, tap None.
  6. Tap the back < arrow to save your settings.
The volume of the Motion Warning cannot be adjusted.
Here's visual on how to get to the Motion Warning setting in the Wyze app:
These steps to enable Motion Warning are the same on all compatible devices. However, the Repeat Sound interval shown on the Motion Warning page is only available for AI-based motion detection.
Additional Notes about Motion Warning
There are two types of Motion Warnings: AI-based and Pixel-based. If your camera has a paid license assigned to it (like Cam Plus), OR is a Wyze Cam Floodlight Pro, you have AI-based motion detection.
Pixel-based motion detection is our free version of Motion Warning, which relies on large groups of pixels changing between frames. Motion Warning is available as a U option on Wyze Cam OG, Wyze Cam Floodlight v2, Wyze Video Doorbell v2, Wyze Duo Cam Doorbell, and Wyze Cam v4.
For pixel-based Motion Warning on the devices listed above, when a motion is detected in the detection zone, the camera plays a selected warning audio message through its built-in speaker.
