My affiliate link isn't working.
If your affiliate link is not working, we recommend making sure that you're using the correct link provided by Pepperjam Ascend. After applying to Wyze Affiliate Program, you should have received an email with steps to generate your affiliate link. You'll want to make sure you're using that link on your website, blog, social media post, etc.
To generate your link, simply log into Ascend and select Tools Link Generator.
