Which Wyze Cams are compatible with Wyze Bird Feeder?
Wyze Bird Feeder works with:
  • Wyze Cam Outdoor v1/v2
  • Wyze Cam Battery Cam Pro
  • Wyze Cam v3, Wyze Cam v3 Pro, Wyze Cam v4*
If using a wired Wyze Cam, you'll need a Wyze Outdoor Power Adapter to plug it into power.
