How to install a camera into Wyze Bird Feeder
To install a camera on Wyze Bird Feeder:
  1. Slide the lens bracket over the camera lens
  2. If you have a Wyze Solar Panel installed, connect the power cable to the camera.
    • Wyze Battery Cam Pro and Wyze Cam Outdoor require this connection to work with the solar panel.
  3. Mount the camera onto the camera bracket from the bird feeder, pulling the cord through the hole.
  4. Use a screw from the mounting kit to secure the camera to the bracket.
  5. Mount the camera bracket onto the main body of the bird feeder.
  6. If you have a Wyze Solar Panel installed, connect the power cable from your camera to it now.
  7. Last, manually adjust the camera's viewing angle using the Wyze app.
Wyze Bird Feeder is compatible with:
  • Wyze Cam Outdoor v1/v2
  • Wyze Cam v3/v3 Pro/v4
Follow along with the video below for how to add a compatible Wyze Cam to Wyze Bird Feeder.
  • Live Support Hours:
