Automations help control your Wyze devices through Shortcuts, Schedules, and Device & Service Triggers. This reference article lists all of the triggers and actions available on Wyze Bulb White.
💡 A trigger is what happens to start an automation, like a command. An action is the result of that trigger, or the task you want your device to do.
Wyze Bulb White Triggers |
Wyze Bulb White Actions |
Turns on Turns off Has been on for Has been off for
Turn on Turn off Turn on for Turn on Vacation Mode Turn off Vacation Mode Set color temperature Set brightness to Turn Sun Match Off Turn Sun Match On Color Temperature Blink |
Related article: Using Automations with Wyze Bulb White
